Deleting Labels
rab108
Deleting Labels
Post by rab108 »
If a catalog label is deleted...
(a) The metadata remains in the file, correct? Just checking...
(b) How do I repopulate the Catalog with the label that was deleted?
Regards,
Allen
Re: Deleting Labels
A) if you have auto sync switched on then the deleted catalog label will automatically be removed from the metadata as well. If you have auto-sync switched off then it will still be in the file (assuming that you didn't sync manually)
B) on Windows, press Ctrl-Alt-S, on Mac that is Cmd-Alt-S
