Hi
can i send a photo directly to dxo 9 (to the customize module ) ?
because when i send a single (named test.cr2 for example )photo to dxo 9 , dxo 9 starts to create the cache of all the photos in the same test.cr2 folder and it takes time , lot of time (depends on the number of photos)
i 'm sure the dxo 9 behavior
but maybe there is a trick to send a single image , avoiding the creation of the cache of hundreds of photos
in the guide there is no mention to the command lines
thanks
can i send a photo directly to dxo 9 customize/develop ?
Re: can i send a photo directly to dxo 9 customize/develop ?
Hi Mantras, Photo Supreme sends the file to DxO by starting it with the files as command line parameters. How DxO handles command line parameters is outside of PSU's control. But if you can figure out is DxO supports a parameter to open the file directly in the editor then that would be great and such a parameter could be added to PSU. In fact, I want to provide optimal support for integration between DxO and PSU and so every improvement in that area is more than welcome.
Just switch DXO into Project mode - then it will show only the Pictures witch you sent from PSU
Hert, in the following tutorial the workflow between DxO and LR is being described:
http://www.dxo.com/intl/photography/tut ... -lightroom
Is this interesting for you? Would you be willing to implement this way in PSU as well?
Sure, the better the integration with DxO, the better and I'd be the first to cooperate.
PSU's feature set is complimentary to that in DxO and if DxOLabs would also work on integrating with PSU then that would be more beneficial to their and our customer base.
- Contact:
There's nothing in the DxO Preferences to set Project mode as a default, but the Folders/Projects tabs are sticky. So, Open DxO, select the Projects tab, then close. The next time you send a file to DxO from PS, it should open the file as a project.Guido2014 wrote:Just switch DXO into Project mode - then it will show only the Pictures witch you sent from PSU
Photo Supreme 2024; DxO PhotoLab; Affinity Photo; PhotoLine; Luminar Neo; macOS Sonoma; Mac M2 Studio
