Change Versioning After Initial Import?
Is it possible to change the versioning option once the images have been Imported. If I understand versioning correctly this is the feature that allows you to tell the program whether to default to the JPEG or RAW file. I'm hopeful if I have one of each I can tell i to pay attention to just the RAW. If so can this be done after the Import since I didn't figure this out until Importing my first batch of images.
Re: Change Versioning After Initial Import?
When you change the versioning option then that option is for future imports.
There is a script that allows you to change version placeholders for existing versions.
http://repository.idimager.com/cgi-bin/ ... dfc5178d35
