Is there a handy list of command macros somewhere?
flossie
Post by flossie »
Hi there,
Particularly, for camera model, e.g. iPadmini, or iPhone4S...
Reason: I'd like to batch rename my files on import with the following rule: %yyyy-%mm-%dd_%CameraModel_%FileName.%FileExtension
However the part %CameraModel doesn't work! Its just inserted the words 'CameraModel' !
If anyone can help that would be great, as the filenames for my iPhone4S and iPadMini are not unique, they are all IMG_xxxx so will of course overlap.
Many thanks!
Re: Is there a handy list of command macros somewhere?
In the Import Module, for the naming rule, choose Custom defines and that gives you a dialog with the elements in your rename rule. Use the drop down arrow to select from any possible macro command.
flossie
Post by flossie »
Great! Thanks!
