Color labelling shortcuts
Tom
Post by Tom »
Just installed the version 1.5.0.89 and noticed that color label assignment works nicely now.
(BTW, would appreciate to read the announcement about the improvements since the version 1.5.0.85).
My question: is it possible to customize shortcuts for color labels? Simply because it is cumbersome to hit Ctrl+number while editing a large number of images after downloading a shoot. Thanks.
Toomas
Re: Color labelling shortcuts
Tom wrote:Just installed the version 1.5.0.89 and noticed that color label assignment works nicely now.
They are bug fix releases. Nothing significant to announce.
You can't change shortcuts. If you're in the Viewer then you can also use 6-9 for the first 4 color labels.
Post by jstartin »
IDimager wrote:
Tom wrote:(BTW, would appreciate to read the announcement about the improvements since the version 1.5.0.85).
Really ? :wink:
Like I said...nothing significant. This menu item is what Ctrl-Shift-V already did.
Post by Mike Buckley »
IDimager wrote:This menu item is what Ctrl-Shift-V already did.
Considering that the shortcut isn't documented in the Help screen or the Sticky post, it would be difficult to know that it already existed or even exists now.
WIanB
Post by WIanB »
Ctrl-Shift-v, umm...welcome, where have you been hiding then :-)
On a more serious note, are there any other undocumented short cuts? And can the "shortcut sticky" please be updated.
Ian
Home build - AMD 8 core 4.0 GHz, 16GB RAM, Windows 10. Photo Supreme 64 bit, Adobe Photo CC
