Photo Supreme - Display Issues with 64 version
Menace
Post by Menace »
I am working with Photo Supreme 64, but in the assign Tab there are always problem. For example if I am starting "untagging" some keywords, the keywords aren't shown anymore. I have to restart Photo Supreme. Sometimes PSU shows "Access violation (0)".
Untagging a lot of images are slower than IDimager 5 Pro and less stable.
Re: Photo Supreme - Display Issues with 64 version
I was able to reproduce this here and a fix will be released soon.
Btw; The recommended place to report bugs is at http://bugs.idimager.com
Maybe you have some of the groups open in the LAP, for instance "SUGGESTED" or "NEARBY LABELS" when these are open the content needs to be retrieved and those are "heavy" queries. Best to keep these closed when you need performance. "RECENTLY USED" and "FAVORITES" don't claim performance.
Menace
Post by Menace »
IDimager wrote: Maybe you have some of the groups open in the LAP, for instance "SUGGESTED" or "NEARBY LABELS" when these are open the content needs to be retrieved and those are "heavy" queries. Best to keep these closed when you need performance. "RECENTLY USED" and "FAVORITES" don't claim performance.
I just have my own sets open. BTW, is there a possibility to change the GUI-Colors or Styles? Des Assign-Panel is (for me !!) to shiny. I prefer less contrast, less "rounded" buttons (Lightroom 3 gui, I like a lot).
Then, in theory, it should be faster than IDimager.
No. The application comes as it comes.
Menace
Post by Menace »
No, unfortunately not (12 GB RAM, Phenom II 940 Quadcore). But in one set there a long keywords (species-names in german and the scientific-name) and a set have 48 keywords. Scrolling is far away to be "smooth".
Ok.
Maybe you didn't read the other question in the IDImager Pro Forum:
IDimager wrote:And the way it writes keywords is identical to IDimager.
I didn't find in Photo supreme where I can choose the Exif/IPTC-Code like in IDimager to chose it like I was written it in IDimager in UTF-8 (was the standard, or)? In which way are writing Photo Supreme the keywords and how can I change it, if it is not UTF-8.
PSU always writes in UTF8 mode; not configurable.
The next update will write the encoding method in IPTC
Menace
Post by Menace »
IDimager wrote:PSU always writes in UTF8 mode; not configurable.
Thank you, Hert. This will be a great help.
Something really confuse me.
Currently my workaround is.
IDimager Pro 5:
Tagging images --> Write to the file (hierarchical utf-8) --> Exiftool -IPTC:codedcharacterset=utf8 <*.jpg> --> Result: All is shown perfect in Exiftool-Gui; even my name in copyright.
Example: Keywords|Systematik|Vögel|Neukiefervögel (Neognathae)|Sperlingsvögel (Passeriformes)|Singvögel (Passeri)|Finken (Fringillidae)|Edelfinken (Fringilla)|Bergfink (Fringilla montifringilla)
Photo Supreme (after open the database from IDimager Pro 5)
Tagging images --> Save metadata to the file --> Exiftool -IPTC:codedcharacterset=utf8 <*.jpg> --> Result: Some signs are shown wrong in Exiftool-Gui.
Example: Miscellaneous|Systematik|V�gel|Neukieferv�gel (Neognathae)|Sperlingsv�gel (Passeriformes)|Singv�gel (Passeri)|Finken (Fringillidae)|Edelfinken (Fringilla)|Bergfink (Fringilla montifringilla)
Menace
Post by Menace »
Sorry, I make a mistake: Some signs are shown wrong, after I write it to the files with Photo Supreme.
That's no problem; but you made your point clear and I was able to tackle this (I hope). The next update would have to show that. However, the results from IDI and PSU should be identical (if IDI is set to UTF8)
Menace
Post by Menace »
Thank you, Hert.
Menace
Post by Menace »
Now it's working perfect.
I have just to find out, why I can't move images from one folder to the other via Drag & Drop. :D
