Raw Imgage Size
Raw Imgage Size
Post by tstoddard »
According to the information panel, all of my nef files have an image size of 160 x 120. I also looked in the XMP tiff and exif namespaces and the fields that contain width and length parameters also show a width of 160 and length of 120 pixels. Is this a Nikon issue or a PSU issue?
When I view the same images in ViewNX2, the file info metadata has a field described as "Image Size" and contains "L(4928x3264)".
Re: Raw Imgage Size
What is your Nikon camera model?
Re: Raw Imgage Size
Post by tstoddard »
Nikon D5100
Re: Raw Imgage Size
Thank you, your model will return the correct dimensions with the next update.
MarqsM
Re: Raw Imgage Size
Post by MarqsM »
Now the same situation is happening with D780 NEF files - as per screenshot below.
All of them show a resolution of 160 x 120 which is, of course, incorrect.
Can we please ask for a fix?
[ external image ]
tylerdurden
Re: Raw Imgage Size
Post by tylerdurden »
Hert,
You probably already know this, but my two Nikons have shown the same issue: Z6 and D300.
I'm assuming the upcoming fix will apply to all the recent Nikons.
Thanks!
Re: Raw Imgage Size
In the next build the D780 camera will show the correct dimensions. You will have to use Metadata -> Convert Metadata to XMP first to get the full size dimensions.
PS. this is a user-to-user forum and users cannot make changes to the software and so you're addressing the wrong audience. In the future, best to send a message as explained in my signature here, as well as in the forum rules.
Re: Raw Imgage Size
Build 4895 is now available. You can download it from the website or the Control Panel
MarqsM
Re: Raw Imgage Size
Post by MarqsM »
All is OK now with NEF files from Nikon D780. Thank you, Hert, for a quick update.
