Not saving changes
Coolbanana
Not saving changes
Post by Coolbanana » 26 Sep 12 21:34
I've just installed Splash, picked out a flower photo, used the yellow selection and then made some fine tuning using monochrome.
But it won't save the changes! The yellow selection is fine, but the fine tuning doesn't save.
The original size is 5184 x 3456 and this hasn't changed when I save. I tried downsizing but no difference.
Any ideas?
Re: Not saving changes
Post by Hert » 27 Sep 12 13:12
I just did a quick test here 4123x2753 pixels image and after saving the output to the desktop, I can see all the changes.
You mention iPhoto, so I do assume that you're on the Mac(?)
What is the image format that you're starting from? And what is your output format? Also, are you saving to a new file or do you overwrite an existing file?
Coolbanana
Post by Coolbanana » 27 Sep 12 13:58
Yes, I'm using iPhoto on a MacBook Pro.
I too have tried saving to the desktop as a new file but to no avail. The original example I'm using is in .jpg and saved as one too.
hunypowell
Post by hunypowell » 26 Nov 12 2:27
Have the same problem. huhu:(
