Small thumbs in Lighttable
JimiV
Post by JimiV »
OK, I've selected 4 images (cr2) files. I select Light table. All I get is tiny little images. I don't see how to make the thumbnails full size. I've seen it on individuall images, but not in the LT.
Who thought it would ever be a good idea to have these tiny images display anyway?? And is there a global setting to display image previews that are actually worth looking at?
IDimager Pro 5x
Bibble Pro 5x
PhotoMechanic, Lightroom 3x
Canon stuff
mphillips
Re: Small thumbs in Lighttable
Post by mphillips »
Hi JimV
Not sure what the problem may be ?
Have you tried clicking on the Zoom - View Image Best in the Toolbar at the bottom of one of the images in Light Table
If you can't see the toolbar hit the Up Arrow
Regards
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
JimiV
Post by JimiV »
view image best just gives me the small thumbnail showing at 100% (which is wrong)
IDimager Pro 5x
Bibble Pro 5x
Canon stuff
mphillips
Post by mphillips »
A Flyer :-) But try and rebuild the thumbs (Ctrl Alt T) ?
MikeP
Mike Phillips
JimiV
Post by JimiV »
That got it! Thanks!!
IDimager Pro 5x
Bibble Pro 5x
Canon stuff
mphillips
Post by mphillips »
Hi JimV
Brilliant - Just some info please
Did you migrate you thumbs database from V5 ?
If so were you storing previews in the V5 Database ?
Regards
MikeP
Mike Phillips
JimiV
Post by JimiV »
Yes, I migrated it and Yes I do store them.
IDimager Pro 5x
Bibble Pro 5x
Canon stuff
mphillips
Post by mphillips »
Darn!
I was hoping that the problem was that the previews weren't stored in the database (as it came from v5)
BTW if the size of the previews stored in V5 were bigger than 1680 (the max size for Supreme) its worth rebuilding all the thumbs and previews in Supreme - it will "right size" them for supreme and also save disk space.
And of course if the previews were smaller than what you (one) has set in Supreme then a thumb rebuild should also be on the cards.
But still don't know why your problem existed :-(
Regards
MikeP
Mike Phillips
