Migrating from IDI-5 to Photo Supreme
Nedsez
Post by Nedsez »
Hi all......Help please
Photo Supreme looks an easier tool to use for me.
I no longer have IDI v5 on my system but I do have A full backup available, which includes the idimager.cat and idimager.thumbs database files.
Do i need to include any more files from the backup than just the two catalog folder files ?
All the Very Best,
Nedsez
Instant success can take years to achieve....
I'd best get a move on??
Nedsez
Re: Migrating from IDI-5 to Photo Supreme
Post by Nedsez »
Hi Mike....thanks for your reply, my poor old brain struggles!!
I don't have a %localappdata%\idimager\catalog file folder to copy files from.
I have a full IDI with IDI cat and IDI thumbs files and lots of other files which I don't know which if any I should transfer.
Also i have no %localappdata%\idimagersystems, inc\catalog folder
So should I make one and if so where should I place it, then should I copy my backup catalog and files thumbs files
All the Very Best,
Nedsez
Nedsez,
If you've started pus once then the folder should be there
%localappdata%\idimager systems, inc.\Catalog
It you can't find it, try to go to the %localappdata% folder and open the appropriate sub folders
