Renaming Files
tvandawalker
Renaming Files
Post by tvandawalker »
Trying to figure out how to rename files using the batch tool to the format "year_month_customname_seq#.nef" and I can't for the life of me figure it out. What am I missing. This is so easy to do in other apps.
Tim
mphillips
Re: Renaming Files
Post by mphillips »
Hi Tim
Use the Batch - Rename File Function.
In the Rename Select text and enter %yyyy_%mmm_Customname_%imagenumber{increment=1;offset=0;length=3}.%FileExtension
Then Run the Batch on the images you want to rename (test images first of course:-))
I find it easier to type in the text (even though the window is small) rather than fiddle with the adding of field selectors and trying to shuffle them into the right order. use the field selector drop downs to "get" the fields syntax and fine tune it in the text window.
The details on Image number are from the IDimager Version5 help file:
21-03-2012 22-21-13.png (50.64 KiB) Viewed 4972 times
Regards
MikeP
Mike Phillips
http://www.mikeandmorag.co.za
tvandawalker
Re: Renaming Files
Thanks, very helpful.
