Hi Stephen,
I do not use versions. I keep the metadata between RAWs and JPG identical.
Actually I very much doubt that this is possible without versioning and cascading.
Just a simple scenario:
You have a RAW and you have a JPG. Now you apply the color label "red" to the RAW file. That means it metadata just got modified. If the JPG was a version of the raw you could easily cascade the metadata down into the JPG. Else you have to manually apply the "red" label now to the JPG as well. Now, for a single file both are just one additional step. But as soon as you deal with thousands of files, I very much doubt even the most disciplined users will be able to make sure the data are consistent across the files that belong together (the originals and their derivatives).
May I ask why you are so strongly opposed to using versions for this task??? It seems to me that is exactly what versioning was designed for: keeping data in sync across several derivatives (= versions of the same file).
I generally have dozens at at time, so still very tedious
Yes, and therefore, in my opinion cascading down metadata (also the technical ones) makes perfect sense!
@Vlad:
(Side question:
Do all of you use version sets to group together images derived from the same shot? That may be the most common use case, but I could imagine someone using a version set to group together images of the same subject, taken with different cameras and/or lenses, and possibly at different times and with different settings. You wouldn't want blanket cascading in such a case, right?)
The fact that some users might use versioning for what it was not designed for is not a good argument against cascading technical metadata! In fact the example you mention is a case of stacking images, not versioning! But I guess the confusion is understandable because PSu never offered stacking as a feature.
I think the fact that actually some technical metadata are being cascaded in PSu might be evidence that this is in fact not a feature but a bug: IDI did offer the option to cascade all metadata (via direct file operation). That choice was removed in PSu and as a result now some technical metadata are apparently cascaded, while others are not. This inconsistency does not make sense to me.
Much more logical would be to again add a simple choice, currently the options are:
- cascade Image Details (XMP)
- cascade ratings
- cascade color labels
- cascade GEO coordinates
Why not simply add a fifth option?
- cascade all metadata (including technical camera data)
That would be MUCH more convenient for fixing metadata of a derivative file (= version) messed up by a third party program like C1. Much more straightforward, much more efficient than running XMP CSV Export and the XMP CSV Export script!
