For those who like a functional rating bar
Re: For those who like a functional rating bar
Post by weidmic »
You mean the star with the number in it?
If so, no, that is not possible...
That star is part of PSU's default rating system. If you have not rated an image you can hover over the area, where this star will appear, a small arrow appears, you click on that arrow to open a rating bar and assign the star(s). Once you thus assigned a rating to your image, the star with the number appears automatically.
Obviously, once you use the script here to crate a rating bar this entire functionality becomes redundant. The rating bar essentially emulates a way this worked in a previous system. Personally I find the default implementation how to apply a rating to an image a bit of a challenge. One needs quite a bit of dexterity and several clicks to get it working. In my opinion this script to add a functional rating bar is fantastic. I can live with that other now redundant star still showing up ...
The script in the opening post was just updated.
@Mke; does that fix the Access Violation on your machine?
Hert wrote: 02 Mar 18 9:52 @Mke; does that fix the Access Violation on your machine?
The previous version of the code has actually been working OK since I removed the 'phantom code' (viewtopic.php?f=57&t=26749&start=15#p118974).
But the new code is working fine too.
...although I did get a crash (details below) after pasting in the code and on applying my first rating. Not reproducible - just a one-off.
Problem Event Name: APPCRASH
Application Name: IDimagerSU.exe
Application Version: 4.0.1.1032
Application Timestamp: 00000000
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.3.9600.18666
Fault Module Timestamp: 58f33794
Exception Code: e0465043
Exception Offset: 00000000000095fc
OS Version: 6.3.9600.2.0.0.768.101
Locale ID: 2057
Additional Information 1: 0f33
Additional Information 2: 0f33396c542a776f42769b20b7878a90
Additional Information 3: 75f7
Additional Information 4: 75f78c3aa0df9d315aa67e203de154b8
Exception Code: c000041d
Locale ID: 2057
Additional Information 1: 5319
Additional Information 2: 53199e52b225fb9ac90d19fb5123b900
Additional Information 3: bb5d
Additional Information 4: bb5dedb13109489cffdf4661bf32cfb7
