Dynamic collection by month
jtk
Re: Dynamic collection by month
Post by jtk »
I got it to work. Thank you for your help.
Greetings from Germany
Thomas
MacBook Pro with macOS BigSur
jtk
Post by jtk »
The HDD is working the whole time, does PSu write the data into the files? I just wanted a dynamic collection by month with no entries into the files because the date is already in the exif data.
sanphotgn
Post by sanphotgn »
If your Write settings are enabled to write changes when changes are made to the metadata, the answer is yes. Custom fields are XMP fields. I have two custom fields that contain "duplicate" info, but it makes the process easier. In my workflow, I use a macro directly in a field on the Details panel. The XMP is rewritten, but only takes a minute or two for several hundred images. I haven't used dynamic collections so I don't know if they require a lot of database writing in addition to the changes in the XMP.
jtk
Post by jtk »
But when you introduce an new custom field for your complete library, you don't have several hundred images, my library has over 80.000 images.
I hope that Hert reads this and find a way to introduce the exif-date in the technical details.
But I want to thank you for your efforts.
Thomas
jtk
Solved: Dynamic collection by month
Post by jtk »
Solved with Version 4.1
Thank you.
