POLL: What is your monitor's resolution?
What is the shortest side of your (main) monitor's resolution?
Lower than 900
1
2%
900
1
2%
1080 (Full HD)
13
24%
1200
10
18%
1440 (2K)
13
24%
2160 (4K)
8
15%
2880 (5K)
3
5%
Higher than 2880
6
11%
Total votes: 55
joeldinda
Re: POLL: What is your monitor's resolution?
Post by joeldinda »
Actually 2560 x 1600; chose 1440 as closest.
NathanTaf
Post by NathanTaf »
I'm still sporting a 1080p full hd monitor. I've been looking upgrading to 4k in the near future though.
Henry-In-Florida
Post by Henry-In-Florida »
Dell Monitors. Dual screens. The rated resolution since it's Retina= 6016x6x3384p. UI can see it as a 3840x2160. However, its UI currently set to 3008x1692 @ 60 Hz, 30 bit color (I have it reduced due to the menu and text sizes in MacOS). Can expand on the fly if the app supports it. What does PSu determine to see it as? The system setting.
In the System Report it looks like the settings attached. The monitors are calibrated using DisplayCal. I deal with RAW images @~5500p in the long dimension.
Screen Shot 2018-04-29 at 16.32.09.png (771.21 KiB) Viewed 2341 times
PSu4 Trial mode, 4.1.0 (1448), 64 bit  MacOS 10.13.4  MacBookPro 2017, external RAID storage; Photographer with Canon equipment, shooting RAW [.cr2] Lightroom 6 User.
