@Stephen
did you file the bug in Mantis?
Photo Supreme and Capture One 9
Re: Photo Supreme and Capture One 9
Thanks, but I always sync after an initial import into PSu.weidmic wrote:Try this: after you imported the images into PSU - select all images and CTRL+S (to save metadata)
Then open C1 - do your edits create new files etc.
Then you can run the verify folder in PSU...
I do that all the time and it works pretty well. I believe there is something little going a little wrong after initial import into PSU
It is interesting to note that C1 creates a folder with .cos extension files for ALL files in the directory, whether or not you have selected them, i.e. I mark 6 files for editing from a directory of 100 files and open C1 from PSu. While I am editing, C1 is creating a .cos file for all 100 images. It also creates additional .cof and .cop files in a cache folder for the 6 edited files.
Then when back in PSu, if I verify the folder, it shows updates for ALL 100 files, which I do not accept. Even though all 100 files are not shown as being out of sync, if I mark and sync them again and re-verify the folder, then I do not get an update request. So it appears to be necessary to sync all files in the directory before and after using C1.
Not yet. The task in hand was a one-off, but reflects in other scenarios too.oversampling wrote:@Stephen
