My workflow is the same as Larry's. We both 'export' RAWs to C1 and import a JPG to PSu. Without complicating the workflow any further, could the meta data from the original RAW, which is stored in PSu anyway, not be used to reconstruct the missing data when the processed JPG comes back from C1?fbungarz wrote:Hi Larry, what you write about C1 sounds pretty scary. I wonder if a possibility might be to use PSu to fix the mess they make. An option could perhaps be to create an additional subversion of a file in PSu...
Users would have to be diligent and not expect any meta data / colour / rating changes made in C1 to be retained. I could certainly live with that.
As far as I understand, the C1 specific 'sidecar' files, cos, cof, etc., contain only the adjustment information made when editing the RAW file.[/quote]fbungarz wrote:If I remember correctly from my own trial of C1, it doesn't write raw adjustments of the files into the XMP, but generates some sort of C1 specific sidecar files? In that case having PSu overwrite the XMP that was messed up by C1 would not be a problem, would it? Cascading the metadata back into the file from the untouched main version should then work.
Not sure that I follow all of that but C1 definitely DOES trash the maker notes! I believe that happens because they change (possibly just) one field. Wikipedia says that changing a preceding field can trash all maker notes.fbungarz wrote:Of course we are talking about XMP only here. I am not entirely certain to which kind of metadata PSu's metadata operation "convert metadata to XMP" applies. I am pretty sure Exif and IPTC is included, but not so certain about Makernotes. So, if C1 messes with data are not migrated to XMP with "convert metadata to XMP", then this information may indeed irretrievably lost.
HOWEVER, if PSu has this data from the original RAW file, then perhaps it can reassembled?
Thanks for doing so. Infact this extra step is not necessary. You could stack the images on import (I don't - it's an extra step I don't need) and retrieve the camera exif data (not the maker notes) with the exception that Larry points out. EITHER you get the Lens Description and no more lens data or you can retrieve it, but then you lose the focal length. I personally need to know both lens description (was it a zoom 35-70?) AND which focal length was used. In any case the Lens Description can be added manually in PSu, but the focal length used CANNOT.fbungarz wrote:Just thinking out loud
I could post screen shots but that function appears to have stopped once again.
This matter was discussed a year ago and I supplied IDimager with detailed files of camera RAW, RAW after importing into PSu, JPG leaving C1 and JPG after importing to PSu. That was with version 7 and version 8 showed similar results.
Frank, I am sure that this could be achieved within PSu.
