If space is a constraint for you then, as you yourself also suggested, use another drive than your SSD.
@toomas, when using a smaller size then the database can't grow
Why?You should not migrate your IDimager thumbs database to PSU; It's better to let PSU create a new one...
Hert - I am really not trying to be difficult here. I am just trying to find a workable solution. Like I said, I have 40GB left on my SDD and there is no way that (even using PSU smallest thumb setting) I can risk filling that up with a 20GB thumbnail database! It is simply not good practice to fill an SDD up to the brim. Yes, newer SDDs are less prone to failure, but even they will not last long if all write cycles are confined to a very small part of the disk because everything else is full.We can talk about it but that won't make it any smaller.
Hi Frank. That's not my understanding of how solid state drives (SSD) work. Except for the very oldes ones, they have a scheme of static or dynamic wear leveling to insure that write/erase cycles are distributed evenly across the drive.Frank wrote:Yes, newer SDDs are less prone to failure, but even they will not last long if all write cycles are confined to a very small part of the disk because everything else is full.
Under the "tools" menu there is an item to "Compact the Database". That is what I used.@toomas, when using a smaller size then the database can't growless data still means less space. Are you sure the database is compacted?
