the processed files, putting in a map?
Lieljan
Post by Lieljan » 25 Aug 16 15:31
Good afternoon,
I am a new user of BDsizer, I downloaded the free trial and was very happy
So I bought the version and tried it, only I don't fined a button to say in which folder the processed photo's must come.
Can you told me please what I have to do there for?
Thank you for a solution, kind regards, Lieljan
Re: the processed files, putting in a map?
Post by Hert » 25 Aug 16 22:10
Thank you for choosing IDsizer.
After sizing the images, the application will ask you what to do with the downsized versions. One of the options there is to move them to another folder
Lieljan
Post by Lieljan » 25 Aug 16 22:36
thank you for this answer Hert,
I shall try to found this!
Lieljan
Post by Lieljan » 25 Aug 16 22:39
Thank you very much: it works!
with kind regards, Lieljan
