Idimager 5 to Photo Supreme 4
BertiIrmo
Post by BertiIrmo » 12 Feb 18 16:46
Is the migration from Idimager 5 to Photo Supreme the same as described here?
Migrating from IDimager V5 to Photo Supreme
Post by Hert » 18 Sep 2012, 15:10
Re: Idimager 5 to Photo Supreme 4
Post by weidmic » 12 Feb 18 17:39
PertIrmo,
I think you are refering to this post:
viewtopic.php?f=65&t=18225
This is as far as I am aware still the same.
Though, not sure about recreating the search data, but it can't hurt (it takes pretty long though, best you let run it overnight)
I recommend that you do a compoact/repair before you backup your idimager V5 database and once you have a converted photosupreme database, you should do a compact/repair before you do anything else...
BertiIrmo
Post by BertiIrmo » 12 Feb 18 18:11
Danke Michael, werde ich so machen
