Synology Docker with postgreSQL inastallation?
Post by weidmic » 20 Jan 18 11:17
Has anyone tried to install Docker on a Synology drive with a postgreSQL container, running PSU successfully?
https://blog.golimb.com/2017/07/16/syno ... ostgresql/
Thanks for your feedback
Re: Synology Docker with postgreSQL inastallation?
Post by RobiWan » 20 Jan 18 16:04
Why should it not work? The performance will probably be rather bad
Post by weidmic » 20 Jan 18 16:24
I am not saying that it wont work...
The interface has many too settings for my taste and I am just lost :)
That's why I asked - I am not going to waste days to get it running (or even not)
Post by RobiWan » 20 Jan 18 19:39
I'm not sure which interface you mean.
If from PSU - that's simple. If Postres - simple too. Docker - I don't know and I don't use it.
tweebee
Post by tweebee » 27 Apr 18 21:42
I'm running postgreSQL 9 on Docker on my Synology. I haven't update to Photo Supreme V4 yet, but when I do I will also go to postgreSQL 10.
Username
Post by Username » 28 Apr 18 7:02
On a NAS with a proper CPU and enough memory I believe it will work good enough.
It's not that transactional heavy.
Although I would not do it on my off site backup Synology with a small ARM and 512 MB ram :)
I tried setting up Docker on my Mac mini server to run PS on MS SQL through Docker and got so annoyed because it was too much of a headache when I could simply download the postgresapp and have a PG10 db up and running in seconds - literally.
- I'm the user
