Adding Affinity as an editor
hughden
Post by hughden » 03 Nov 17 8:50
Hi
I tried to add Affinity (preferences/other settings - select affinity exe file) but get a message as shown in the attached.
Presumably I am doing something wrong?
Re: Adding Affinity as an editor
Post by Hert » 03 Nov 17 9:01
You're not doing anything wrong. This is not likely related to PSU. You could check why a file can't be created in that folder. Is the disk read only? Is the disk full? Does the logged in user have write permissions? Can you create a file in that folder with Windows Explorer?
hughden
Post by hughden » 03 Nov 17 10:02
ah..permissions!
Thanks.
