Cropped CO images not correct in PSu
Larry56
Post by Larry56 » 19 Oct 17 3:54
I have a some files that I've processed, cropped and exported from CaptureOne 10. The image, when viewed in other programs such as Faststone, xnViewMP, or Windows image viewer show the jpg cropped where CO shows. All is good.
But when I import into PSu the jpg file it does not show the correct crop area. In all cases the resulting cropped jpg photo has a smaller area displayed. I have PSu Capture One edits support set to none.
Anyone else had this happen? FWIW, Lightroom also displays as smaller image. I have not idea why the others don't.
Screen shot from Capture One
co1 crop elephant2.jpg (58.77 KiB) Viewed 909 times
Screen shot of actual photo in Photo Supreme
[edit for additional information]
Re: Cropped CO images not correct in PSu
Post by Hert » 19 Oct 17 6:22
From how you describe it, your image was not only edited with CO but also with LR...and there are LR edits in the metadata of the file. Many tool can’t read those and hence shows the full size image. But PSU and LR can interpret these edits and will show the LR edited photo.
Two options;
1- remove the edits with LR
2- disable LR support in PSU (like you also did for CO)
Larry56
Post by Larry56 » 19 Oct 17 17:35
Thank you Hert for the explanation. It'll also be helpful going forward.
