dropdown list for multiple custom fields
AltoonaBound
Post by AltoonaBound » 13 Aug 17 0:42
Can a vocabulary list be used for multiple custom field autofills? I need the same set of codes to be used in 3 or more custom fields.
Eric
sanphotgn
Re: dropdown list for multiple custom fields
Post by sanphotgn » 14 Aug 17 18:11
Are you looking for something like this:
Custom_Field_1
Apples
Bananas
Cherries
Custom_Field_2
Apples
Bananas
Cherries
Where the custom fields are actually dropdown fields only containing those values?
AltoonaBound
Post by AltoonaBound » 15 Aug 17 17:08
Yes, but I don't want to maintain multiple vocabulary files to support this.
Eric
sanphotgn
Post by sanphotgn » 15 Aug 17 18:49
As far as I know, one vocabulary text file to support two or more custom fields is not possible.
AltoonaBound
Post by AltoonaBound » 15 Aug 17 19:32
yup, that's basically what i'm seeing unless there's some fancy scripting i don't know about. 8)
Eric
