Flickr authorization does not work (Hert solved it!)
KeesdH
Post by KeesdH » 12 Aug 17 8:11
I am trying to authorize Photo Supreme for uploading to Flickr. When I follow the process I get to the homepage of Flickr instead of in the authorization process.
Anybody experiences the same or has a workaround?
It could be this issue I found on the Flickr forum regarding Photo Mechanic:
It seems Photo Mechanic was using an older (i.e. outdated) authentication version that is no longer available. Third party apps and sites that integrate using that old auth method will need to update to OAuth, a more secure and more current authentication method.
IFTTT also falls in this bucket.
Any help appreciated.
Re: Flickr authorization does not work
Post by Hert » 18 Aug 17 18:12
I've uploaded build 2603 to the server that should support the new Flickr authentication system. Can you confirm that it work correct now?
KeesdH
Post by KeesdH » 18 Aug 17 18:58
Hert, I just checked. Authorization went fine and uploading worked as well.
Thanks for solving this issue.
Kees
Post by Hert » 18 Aug 17 21:49
That's great. Thank you for confirming.
