TSQLServerConnection : Error 20009 :
ebw
Post by ebw » 11 Aug 17 21:03
New Install - I’m having trouble setting up a new SQLServer database. I’m not very computer literate and I sure could use some help.
I followed the instructions given in the “Installation Guide”, but when I try “Test Settings” I get the following message:
Database connection test failed
Unable to connect: Adaptive Server is unavailable or
does not exist
I’m not sure what to do from here?
Win7 Professional SP1
Intel® Core™ i7-4770 CPU @ 3.40GHz
16.0 GB (RAM)
64-bit Operating System
Re: TSQLServerConnection : Error 20009 :
Post by Hert » 12 Aug 17 5:33
Try to connect using the IP address as the hostname
Also don't forget to add the instance name separated with a backslash
ebw
Post by ebw » 12 Aug 17 22:03
Thank you Hert for your suggestions.
I used my IP address\postgresql-x64-9.3 and port 5432
User Name: portgres and password
But I still can’t seem to setup a new SQLServer database …
TSQLServerConnection : Error 0 :
Can you think of anything else I should look into or double check?
Post by Hert » 13 Aug 17 9:00
Postgresql? The error you get tells me that you installed the PSU-Sqlserver version. Make sure that you install the PSU-postgresql version if you intend to use PSU with PostgreSQL.
ebw
Post by ebw » 14 Aug 17 17:12
Oh my …….. I feel like the village idiot ……
Yes indeed I installed the server version of Photo Supreme. I uninstalled it and installed the correct version and everything is working properly. I’m really excited to start using Photo Supreme.
Hert – Thank you so much for your input. I never would have figured it out on my own.
