Several Albums - same photo on the network
DARADMIN
Post by DARADMIN » 21 Feb 17 22:28
I a systems administrator trying to reduce file space
My PR staff has a habit of setting a folder for every project they have and dumping the same file on each folder they need.
If I would choose to get the sever edition - The use of labels would enable my users to assign the same pic to different projects without repeatedly duplicating files.
I have 2 windows and 1 mac user, several sql servers and the image repository on a NAS.
Other than labels is there an album feature that they can visualize their project like they would do in a folder ?
If you can point me towards some manuals that would be great
Thank you
Nadia
DirkS
Re: Several Albums - same photo on the network
Post by DirkS » 22 Feb 17 0:05
DARADMIN wrote:Other than labels is there an album feature that they can visualize their project like they would do in a folder ?
Yes, they're called Portfolios in PSu
Post by Hert » 22 Feb 17 8:21
As Dirk mentioned, they are called Portfolios.
Click CATALOG->By Portfolio to start creating your own portfolios.
