"License in use" preventing use
stonel
Post by stonel » 09 Jan 17 2:03
I am currently unable to start the Postgresql server version of Photo Supreme on the Mac platform due to a "Your admin license is currently in use" notice.
However, I have the server version installed only on this computer at this time. The only change that I made was to try to install PostgreSQL on my Synology Diskstation. However, did not get to the point of successfully setting up the database. However, it was all from the same computer. Same Photo Supreme license. However, I am now locked out.
How to reset things.
I have shut everything down, reset things, that I know of, deleted the PostgreSQL on the Synology and still locked out.
Thank you
Re: "License in use" preventing use
Post by weidmic » 09 Jan 17 3:25
stonel,
I suggest that you send an email to: support@idimager.com
Hope you get the issue solved soon
stonel
Post by stonel » 09 Jan 17 3:48
It seems to have solved itself after having shut everything down for another couple of hours
Post by weidmic » 09 Jan 17 12:23
Great!
Glad you have PSU working again...
