Wrong date, after import
RaBuDu
Post by RaBuDu » 25 Apr 16 17:08
After importing aprox. 19K JPEG files, I observed, that 11K of them had the worng date in the catalog.
Alle picture are dated to 1899-12-30 (before last century). Opening those files in another application (for ex. Media Pro, Lightroom etc. ) the date is correct.
Thank you for any helpfull statement.
Best regards
RaBuDu
Re: Wrong date, after import
Post by Hert » 25 Apr 16 17:11
Try to right click on one of these images, then select Metadata-Read
RaBuDu
Post by RaBuDu » 26 Apr 16 19:54
I tried this before, but there was no effect.
I did a reimport of the pictures folder by folder (no subfolders) and now all dates a correct.
RaBuDu
Trashcanmike
Post by Trashcanmike » 05 Apr 17 15:11
I had the exact same error but the Metadata reread fixed it. Thanks Hert.
