Re-Read some Metadata from NEF not from XMP
Post by weidmic »
Hert,
Over time I got images with messed up meta-data. I mean the technical stuff that PSU would never touch/alter, normally (lens info, focal length ect.)
The metadata is correct in the NEF file, but not in the XMP-sidecarfile.
So when I re-read, the metadata the xmp-file has priority - and because the focal lenght ect. is not correct written into the xmp-file it does not correct anything...
I would like to reread some of the meta data from the actual "not altered" NEF-File to correct the wrong data in the database.
However, I don´t want to have to catalog the images again...
Can you provide a way to do that?
Re: Re-Read some Metadata from NEF not from XMP
This is possible from the menu in the Image Details
Post by weidmic »
Import to XMP? That's what it is for?
Got to try that...
Post by weidmic »
It works!
Import to XMP is only available with a single file selected...
Is that on purpose? Would be neat if it would work with many files at once.
Regards,
[EDIT: I need to do that for 2000+ images, so one image at a time would be very time consuming]
Post by weidmic »
Hert,
can you provide a way to do this on more than one image at a time?
Regards,
Feature requests can be posted in Mantis at http://bugs.idimager.com
Post by weidmic »
I think I know that already ;)
I have thought about a script on selected images - because that issue might not concern everyone. I want to correct the"mess" that has most likely been created by some beta versions and not by official releases.
BTW: The way that multiple and single selected images are covered in the image details is inconsistent, and I have made a FR regarding this already. Maybe not that obvious but it would cover this too! The last one was 1333.
Regards,
Post by weidmic »
Read metadata just does not cover most of the problems my problems, only import to xmp - please make it possible to import to xmp for multiple files.
Maybe this helps??
http://repository.idimager.com/cgi-bin/ ... 1cf5a2d130
Maybe you need to delete all the progress usage but it should get you started.
Post by weidmic »
I don't think I can get that to work... :shock:
Why not?? Just delete all the progress stuff, what's hard about that?
Post by weidmic »
Nothing, if you know what you have to do...
Lol. That's true. Delete every line that includes the word "progress" ;)
Post by weidmic »
then it says canceled...
but nothing has changed!
edit: figured it out - a line is not a line is not a line!
Great Michael. So now you're an experienced scripter ;)
