Editor Designer Customized Field
palert
Post by palert » 28 Feb 14 6:30
Hello everybody,
I'm absolutely new in this forum and I'd like to raise a question concerning customized fields for IPTC-extensions.
I've the IDimager Pro 5 version and I tried to add a customized field in area "IPTC extension". I added a new item in the group "IPTC extension" in the editor schema designer, specified the properties in "Meta Item Details" and property details.
Image" " Image
But after storing I got only the Tag but no field where to put information in.
After reentering the editor and editing the properties, I got the information "XMP property "Iptc4xmpExt:Clan" not found. Would you like to define it now? But nothing happend if I repeat.
Does anyone know how to do it the right way? Is it possible like that anyhow?
Thanks in advance.
