saving jpeg : green or blue on red lines problem
Alain
Post by Alain » 03 Feb 14 21:30
Hi
I have a strange artefact when saving jpeg files. Diagonal green or blue lines on a red background or not rendered ok. See the included file and compare the green on red versus the green on white or white on red.
I have this a lot when making images for the web (800 pix) even with a quality of 96 and unfortunately this are two times sponsor logo's...
If I let IdImager saves as a tif and then use pwp to save a jpeg it's ok.
Is there a setting inside IdImager to solve it?
Alain
example
Re: saving jpeg : green or blue on red lines problem
Post by Hert » 04 Feb 14 13:07
I've never seen that. Maybe save with a higher JPG quality?
Post by Mike Buckley » 04 Feb 14 14:13
I've created over 10,000 JPEGs using IDimager V4 and V5 and none of them have ever been created incorrectly.
Alain
Post by Alain » 04 Feb 14 17:56
Hi
I used 96 in the example and tried just with 100 with the same effect.
Mike : I hadn't seen it before either, but it's very reproducible. It's also only visible on if you see the image at 100%, which is normal on web pages. I resize it to 800pix and this is displayed.
BTW. The tif is OK and pwp does the conversion good.
Post by Mike Buckley » 04 Feb 14 21:30
Alain wrote:It's also only visible on if you see the image at 100%
99.99% of the JPEGs that I create are always viewed at 100%. Sorry to learn that you're having this experience.
