Editing pane gone, can't get it back
randym
Post by randym » 10 Nov 13 1:13
I somehow made the editing pane disappear and I cannot get it back. I've gone through every menu. What I mean by the editing pane is the pane that allows you to do smart fixes, resizing, etc.
Re: Editing pane gone, can't get it back
Post by Hert » 10 Nov 13 8:35
Hello, most likely you've dragged the panel to a 0-size. If you have a backup of your registry in the IDimager backup then try to restore that. Otherwise, delete (or first rename) the registry key \\HKCU\Software\IDimager\IMB
Btw, when manually editing the registry then do this after IDimager is closed down
