Creating XMP MWG-RS schema for Picasa faces
lauff
Post by lauff » 24 Sep 13 4:17
To see and use the face tags from Picasa 3.9 I try to create a mwg-rs schema in the XMP editor.
Unfortunately I can't find a complete description of the element and data types used in that,
The output from the exiftool looks like this:
<mwg-rs:Regions rdf:parseType="Resource">
  <mwg-rs:AppliedToDimensions stDim:w="2848" stDim:h="4288" stDim:unit="pixel"/>
  <mwg-rs:RegionList>
    <rdf:Bag>
      <rdf:li>
        <rdf:Description mwg-rs:Name="Marius Lauff" mwg-rs:Type="Face">
          <mwg-rs:Area stArea:x="0.326545" stArea:y="0.394706" stArea:w="0.540028" stArea:h="0.430737" stArea:unit="normalized"/>
        </rdf:Description>
      </rdf:li>
    </rdf:Bag>
  </mwg-rs:RegionList>
</mwg-rs:Regions>
Can some please provide help to create the Schema?
Markus
lauff
Re: Creating XMP MWG-RS schema for Picasa faces
Post by lauff » 24 Sep 13 4:36
I found another example.
The part I am interested in is (again) the section around mwg-rs.
(please note that this example does not state the name of the person - which is pretty crucial for a face ;-) )
<?xpacket begin="?" id="W5M0MpCehiHzreSzNTczkc9d"?>
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="Adobe XMP Core 5.4-c002 1.000000, 0000/00/00-00:00:00        ">
   <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
      <rdf:Description rdf:about=""
            xmlns:xmp="http://ns.adobe.com/xap/1.0/">
         <xmp:CreatorTool>Picasa</xmp:CreatorTool>
      </rdf:Description>
            xmlns:mwg-rs="http://www.metadataworkinggroup.com/schemas/regions/"
            xmlns:stDim="http://ns.adobe.com/xap/1.0/sType/Dimensions#"
            xmlns:stArea="http://ns.adobe.com/xmp/sType/Area#">
            <mwg-rs:AppliedToDimensions rdf:parseType="Resource">
               <stDim:w>912</stDim:w>
               <stDim:h>687</stDim:h>
               <stDim:unit>pixel</stDim:unit>
            </mwg-rs:AppliedToDimensions>
            <mwg-rs:RegionList>
               <rdf:Bag>
                  <rdf:li rdf:parseType="Resource">
                     <mwg-rs:Type>Face</mwg-rs:Type>
                     <mwg-rs:Area rdf:parseType="Resource">
                        <stArea:x>0.680921052631579</stArea:x>
                        <stArea:y>0.3537117903930131</stArea:y>
                        <stArea:h>0.4264919941775837</stArea:h>
                        <stArea:w>0.32127192982456143</stArea:w>
                        <stArea:unit>normalized</stArea:unit>
                     </mwg-rs:Area>
                  </rdf:li>
               </rdf:Bag>
         </mwg-rs:Regions>
      </rdf:Description>
            xmlns:exif="http://ns.adobe.com/exif/1.0/">
         <exif:PixelXDimension>912</exif:PixelXDimension>
         <exif:PixelYDimension>687</exif:PixelYDimension>
         <exif:ExifVersion>0220</exif:ExifVersion>
      </rdf:Description>
   </rdf:RDF>
</x:xmpmeta>
gcoupe
Post by gcoupe » 25 Oct 13 10:54
Have you looked at the MWG Tech Specs?
http://www.metadataworkinggroup.com/specs/
Geoff Coupe
lauff
Post by lauff » 02 Nov 13 10:41
Hi gcoupe,
Yes I looked at the MWG spec. In fact I am more struggling with the idimager side.
Markus
